Yamaha Water Temperature
jak
Can someone tell me what the approximate normal running water temperature would be on the top of each side of the block where the temperature sender is installed. Engine is a 2004 Yamaha 150TXRC.
Thanks
yamamarinetech40
Re: Yamaha Water Temperature
There really isn't a 'set' temperature, but you should always be able to put your hand on that location for at least two seconds with no problem. I would expect no more than 150 degrees, ever.
yamamarinetech40
This may help, your thermostats open from 118 to 126 deg. F and your overheat sensor will kick in at 183 to 194 deg. F
jak
Thanks for the information. I’m getting a reading of approximately 120 degrees which appears to fall within these parameters. Thanks again
