My Yamaha T9.9 will not start. Previously, I installed a 10 micron filter inline,
replaced the engine filter, put in fresh gas, and tore down the carbs which looked clean and cleared the jets. I am using my former Force metal gas tank
because the Yamaha 6 gallon will not fit into my fuel locker. It looks clean inside, but maybe the fuel intake is a problem. There appears to be some fuel in the carb because some leaks out when I open the carb drain. Could the fuel pump still be responsible? Can I easily swap out the fuel pump, if that is the
problem? I also believe the carb mixture screw is turned all the way into the
carb housing. I never touched it, and I assume it is ok since it was set by an
outboard mechanic. Is there an easy way to determine if the fuel pump is the
problem? This 2002 was running fine a month ago. I did not see any appreciable amount of dirt in the carb, but could I have missed something, since I did not soak it in any solution, just checked for clear idle and high speed jets being open.
