Yami 9.9 4 stroke no forward gear mid 1990's
mcgyver
I've been noticing that the thrust on my 9.9 hasn't been the same for awhile, thought it was just the currents /wind ect. today put it in forward and no prop movement..is it possible the pinion forward gear could be toast? how do i check that? with the motor out of the water when i put in forward it seems like the gears mesh when i try to turn the prop...... could it be that the pinion is slipping with forward and letting the prop turn but not at the rmps it should? help.....
mcgyver
Re: Yami 9.9 4 stroke no forward gear mid 1990's
Whow, hold the phone.....after a little more investigation...drained the lower end oil to see if i had metal flakes ect...looks like new...put the prop back on, put into forward...and the copper/bronze splined liner in the prop spins! Looks like i need a new prop only!!!!!!! I'm a happy guy....... has anyone seen this happen before? is it common?
