Yami 9.9 screams in neutral
rivrat12
1992 Yamaha 9.9 2 stroke (ESHQ)
Picked this up this spring. Ran fine twice.
Currently it revs really high in neutral (screams). Pulling the choke half way settles it down enough to safely engage F or R. Once it is in gear, it behaves normal
Can a non mechanic like myself address this? Pretty busy next two weeks - not a great time for it to sit on a bench...
thanks in advance if you have any input
Sea Rider
Welcome to Iboats,
When was the last time the carb was fully cleaned to an immaculate internal condition ? Does the throttle grip fully returns to the min slow side ?
Happy Boating
rivrat12
Welcome to Iboats,
Happy Boating
Not sure on carb - throttle does return to min....I was thinking carb, but that's not for me to address - might wait it out a week and get it looked at... Thanks !
99yam40
2 things can affect RPM,
throttle linkage and timing,
a timing light will tell if the timing is too far advanced at idle
did you look at the throttle plates to make sure they are closing back to Idle position?
