Here is the thing, any automotive oil that is decent(castrol, shell, etc) is fine....yama does NOT recommend synthetic oils in it's motors.....the only
problem is that in cooler waters outboards run a lot cooler at times than car engines, and Yamaha especially has had a problem with "oil growth", which
is due to excess fuel that gets past rings into crankcase which is normally burned off(boiled) in combustion engines but since outboards run so cool...it doesn't...so the oils are special to try to minimize this 'oil growth' but most people don't have a problem with this...so you may not need the special oil just a good
Why would Yamaha make a 4M FC-W synthetic if they don't recommend it?
Read the information below and go to the Yamalube page.
http://www.yamaha-motor.com/outboard/apparel/apscitemdetail/3/121/802/1/10100/detail.aspx
Yamalube 4M FC-W? Full Synthetic SAE 5W-30 Marine Motor Oil
Group IV fully synthetic oil offers our best outboard lubrication and performance, and it?s FC-W? rated by the National Marine Manufacturers Association (NMMA?). Contains all of the benefits of mineral oil-based Yamalube 4M, with increased lubricity for lower friction levels and potentially improved fuel economy. Specific marine additives help combat rust, corrosion, varnish, and wear; all while providing high levels of bearing protection, resistance to foaming, and lubrication. Recommended primarily for Yamaha V MAX SHO outboards. Also works well in other Yamaha four stroke outboards (such as the V6 Offshore and F70 models) as well as other brands of marine sterndrive and inboard engines. 5W-30 weight provides excellent lubrication in all climates.
*Please refer to your authorized Yamaha dealer for pricing
32 oz. Bottle Only
LUB-05W30-FC-12 $134.00 *
<-- Back
