Yammy carbs: will 150 carbs fit a 130?
JB
I have a '92 Yammy 130 with 2 bad carbs (salt water bath).<br /><br />ebay has a set of 3 '89 Yammy 150 carbs that will go cheap.<br /><br />The 130 is a V4 that is identical in displacement to 4 cylinders of the 150 V6.<br /><br />Does anyone know if two of those 150 carbs will bolt up to my 130 reed plate manifold??<br /><br />Red sky at night.. .<br />JB :)
jungnim2
Re: Yammy carbs: will 150 carbs fit a 130?
you a the one with the carbs<br />we dont have them in stock
Rex
J. B. Cornwell will you check in on flips<br />member no.5550. I think he could use your help. I'v tried but he has not got to around <br />testing it yet.<br />GOOD LUCK<br />REX A. HUBBLE
