Yard sale grinder
flashback
I picked up a bench grinder at a yard sale and though it runs great the grinding wheels have a bunch of what appears to be aluminum embedded in them. I know someone has run into this. How do you get the aluminum out? Thx.
airshot
Be prepared to get messy, the wheel dressers remove layers of the surface of the wheel along with those aluminum bits. If the wheels are worn down, you might consider replacing them. Belt sander type grinders work far better on aluminium ...
The best way to grind aluminum is to load the wheel up with wax.----Aluminum bits then do not stick in the wheel.
flashback
I'm gonna use my Ace points and get a star wheel dresser, I measured the diameter of the wheels and I think the dresser will clean them up. I have 5 bucks invested in this thing, and it looks like new wheels would be too much coin, so I'll get the spur and learn how to use it. I suppose keeping the surface squared will be the biggest challenge.
airshot
Only limited success doing that as the aluminum creates lots of heat and the wax melts away quickly. Actually oil and grease work better, but makes a real mess
dingbat
You can say that again.
My first job I had to weld up these large aluminum enclosures then grind the welds then finish for painting with a 5 hp Milwaukee grinder, #80 soft pads, a squirt can of oil.
Grinders are for steel
Sanders are for aluminum
airshot
For most fab jobs yes, but as a tool maker for more than 50 years, I spent a great amount of time on surface grinders, precision grinding aluminum for tooling. Sanders cut faster, but often precision fits require grinding.
dingbat
What is a Sander?​
Sanders are designed for smoothing surfaces through abrasion, gently removing material from a surface. They do this by moving sanding discs, sandpaper sheets, or a sanding belt across the material's surface in either a circular or linear motion.
What is a Grinder?​
Picture sparks flying or cutting through metal with ease. Grinders are powerful tools used that operate at high speeds for much more aggressive material removal. They use a hard, abrasive disc or wheel to cut, grind, or polish surfaces.
