Brian Robertson
- Joined
- Sep 10, 2002
- 9
This is a new engine to me - the temp gauge says it is running hot - no alarm sounds - water pump is new and working - one mechanic says it is probably the gauge - also could be sender switch or thermostat - It appears there is a thermostat and sender switch in each head - not sure? Would these be the thermostats that control water flow or just something to do with sender switch? Is there any way to determine which part may be causing the problem or which part to change out first?
