Year and RPM range for my motor 70HP Force ?
diamondlangus
I have a Force motor with the serial # 0E022160. I would like to confirm what year it was made and I also would like to know what the proper Wide Open RPM is for this motor.
thanks
roscoe
Re: Year and RPM range for my motor 70HP Force ?
That was an odd time for serial numbers and models of Force motors.
It was just after the purchase by Mercury, with some motors using the old system, some the new.
Best I can narrow it down to is 1991-1993.
Betting late 1991 or early 1992.
OE000001 - OE065371 1991-1993
Lots of different parts were used during that 3 year period, carbs, spacer plates, tnt units, several different ignitions, fuel pumps, etc.
The most common parts, that were different, were the fuel pumps - square Merc type vs oval 2 stage chrysler type; and the ignitions. Blue coil prestolite ignition - vs Merc early switchbox - vs Merc newer switchbox.
Sometimes you can find a date on the starter, or a white paper production line label on the water jacker, flywheel, or ignition board. It may contain a date, model number, or serial number.
Or, you can post photos of the fuel pump and ignition board, and we can try to narrow it down for you.
Rpm, 4250-5250 or 5500? Mine was set up to run 5600 with an empty boat.
diamondlangus
thanls I will see what I cam find and post some pics. It is on a 1995 Spectrum 16 sport. supposed to have all beem bought new nut I wanted to check.
jerryjerry05
Prop it to run, 5200=5500
Remember what you put in the boat will have a lot to do with performance.
2-3 adults 1-2 fat ones, 2-3 kids a dog and 2 coolers and all the gear and what ever else you wanna pack along.
All this will affect the performance.
Oh yea a huge gas tank full will hurt. My tank is 100 gal. That's another 800# .
So remember what you carry will hurt.
diamondlangus
Just thought I would update ... I sent the serial # to mercury. they said it is a 1993. WOT 4500 - 5500
roscoe
thanks for the update
