steppinstone
- Joined
- Feb 22, 2009
- 48
Hello, I just purchased another project motor from a yard sale
The person had no idea about it just that it had compression the whole motor was spray painted white its made by sears, has forward and reverse gears its a two cylinder, the tag in the front of the engine is badly rubbed off.
The serial #( 700355r121332 ) but I can only read the last four numbers of the model # which is ( 0150 ).the top corner says that its a 141 hp and the inside of the engine cover says it a 16.4 cubic inch . Would any one know what year motor this is and model name or any kind of info or direct me to some one that might be able to help .
ps, would there be an impression on the rear of the tag if I took the tag off or should I not try to do that. Thanks paul
