Year Model and Parts for 3 HP Johnson
Hi,
I have a 3HP Johnson Model# JW21E and Serial# E2640890. Can anyone tell me the Year Model and where is the best place to get a Waterpump Kit? Also, it has a mixture knob on the front; Left to Lean and Right to Rich? I took the screw out and am not sure how to reset it back? Question: Should I turn it All the way IN (Bottom it out) and then so many turns out?
Thanks Jim
bktheking
Re: Year Model and Parts for 3 HP Johnson
Hi,
Thanks Jim
It's a 1966 and Iboats sells a Sierra impeller pump repair kit, comes with the pump base plate and impeller.
part # 18-3201
Not sure about the carb, I have a 52 3hp but i'm sure the procedure is different.
turn2
All the way in ,{not forceful} out 1 turn to start with then fine tune while running.
Thank You...should I assume that it should be full Rich at hi power settings and/or juts adjust to get peak RPM and slightly enriched?
/r/ Jim
1946Zephyr
turning the needle left, will make the mixture richer. Turning it right will make it leaner. Nice motor. I have a 58 model, myself.
When I replaced my water pump, I only needed the impeller. I would suggest buying OEM. I read a post here a couple weeks ago where some one had trouble with a Sierra brand impeller. If you need a housing, likely, you may have to find a good used one, but the dealor might be able to get one for you.
ezeke
Thank You...does anyone offer the housing too?
/r/ Jim
It's cheaper to buy the whole OE kit that comes with the housing than to buy the housing alone. Part # 0379770.
Laingsoutboards sells them for 64.95 if you want to order online, but I would imagine any authorized BRP/Evinrude dealer could get them for you.
