Ah-ha! I didn't catch this reply...if you don't have a reverse, then you don't have a Deluxs.!Originally posted by lurcher:<br /> Very good Ratracer thanks again for information, I note that it only has F+N no reverse, and yes the engine must be turned through 180 degrees for reverse so probably is not deluxe! I did not find any coolant water outlet where you mentioned under rear of powerhead? there is a casting with pipes, the spark plugs are there,quite open infact,I put engine on floor, got torch, and spent good while with piece of welding wire going round anything that might be a water outlet, nothing! Am I looking in right area? Thanks again will check out site you mention. J.B.D.
