Year of Johnson
nimmor
I am looking at buying A 35 H.P. Johnson a co-worker has and was wondering the year. It's model # is RDS-21 and the serial # is 1880626. Also the cover says to mix one quart of 30W oil to 6 gallons of gas. Using 2 cycle marine motor wouldn't hurt it would it?
Paul Moir
Re: Year of Johnson
Model RDS-21<br />Make Johnson<br />Year 1959<br />HP 35<br />WOT RPMS 4500<br />Displacement 40.5 cu.in. = 663.7 ccm<br />Cylinders 2<br />Weight 128 - 138 lbs. = 58.1 - 62.6 Kg<br />Gear Ratio 12:21<br /><br />Please, do use TCW-III outboard oil instead of 30W! It will work much better. With TCW-III it is widely reported to be safe to go to 32:1 instead of 24:1 on that engine. OMC apparently changed their recomendation to 50:1 in a bullitin in the mid-60s. 24:1 won't hurt though, it's just a little smokier..<br />If he has been using 30W, he should decarb the engine. See the FAQ section.<br /><br /> Picture
