Year of Mariner without serial number
garethdeb
Hi Folks
I've recently acquired a second hand Mariner 40hp 2 stroke twin but the plate on the transom bracket is missing. All I can find is a round ally disc just under the engine lifting bracket which has 006512 stamped on it. I've been told that isn't a serial number, but does anyone have any ideas on what it is and how I can find the year of my engine?
Many thanks and regards all.
Gareth
Faztbullet
Re: Year of Mariner without serial number
If it has a lifting ring on the rear of block next to head it is a "import" Mariner made by Yamaha. The number posted will be the last digits of serial number. This motor was made rom mid 70's's till mid 90's and there is usually a serial plate under cowling...
40 M 676B-000106 - 676B-000430 1977
40 M 676A-00346 - 676A-004320 1977
40 ML 676B-300101 - 676B-300140 1977
40 ML 676A-41356 - 676A304150 1977
40 E 676B-100461 - 676B-100610 1977
40 E 676A-10121 - 1977
40 EL 676B-400421 - 676B-401140 1977
40 EL 676A-50631 - 676A-401275 1977
40 M 676B-000431 - 676B-001775 1978
40 M 676A-004321 - 676A-006920 1978
40 ML 676B-300141 - 676B-301725 1978
40 ML 676A-304151 - 676A-309655 1978
40 E 676B-100611 - 676B-102140 1978
40 EL 676B-401141 - 676B-403975 1978
40 EL 676A-401276 - 1978
40 M 676B-001776 - 676B-0036660 1979
40 M 676A-006921 - 1979
40 ML 676B-301726 - 676B-303300 1979
40 ML 676A-309656 - 1979
40 E 676B-102141 - 676B-103260 1979
40 E 676A-100391 - 1979
40 EL 676B-403976 - 676B-406820 1979
40 M 676B-003661 - 676B-005480 1980
40 ML 676B-303301 - 676B-305930 1980
40 E 676B-103261 - 676B-104635 1980
40 EL 676B-406821 - 676B-410850 1980
40 M 6E9-000106 - 6E9-001200 1981
40 M 676B-005481 - 1981
40 ML 6E9-300126 - 6E9-301100 1981
40 ML 676B-305931 - 1981
40 E 6E9-100101 - 6E9-100580 1981
40 E 676B-104636 - 1981
40 EL 6E9-400231 - 6E9-402515 1981
40 EL 676B-410851 - 1981
40 M 6E9-001201 - 1982
40 ML 6E9-301101 - 1982
40 E 6E9-100581 - 1982
40 EL 6E9-402516 - 1982
40C M 6E9-003151 - 6E9-004510 1983
40C ML 6E9-303246 - 6E9-304783 1983
40C E 6E9-101876 - 6E9-102888 1983
40C EL 6E9-407936 - 6E9-411859 1983
40C M 6E9-004511 - 6E9-005895 1984
40C ML 6E9-304784 - 6E9-306713 1984
40C E 6E9-102889 - 6E9-103918 1984
40C EL 6E9-411860 - 6E9-416472 1984
40C M 6E9-005896 - 1985
40C ML 6E9-306714 - 6E9-308698 1985
40C E 6E9-103919 - 6E9-104798 1985
40C EL 6E9-416473 - 6E9-421567 1985
40C ML 6E9-308699 - 6E9-311323 1986
40C E 6E9-104799 - 1986
40C EL 6E9-421568 - 1986
40C M 6E9-008441 - 1987
40C ML 6E9-311324 - 1987
40C ELO 6E9-427343 - 1987 Oil injection
40C ELTO 6E9-502151 - 1987 Oil injection
40C EO 6E9-105514 - 1987 Oil injection
40 M 6E9-008626 - 6E9-009890 1988
40 ML 6E9-311889 - 6E9-314463 1988
40 M 6F6-015221 - 6F6-018404 1988 Marathon
40 ML 6F6-327508 - 6F6-332944 1988 Marathon
40 E 6E9-105664 - 6E9-106223 1988
40 EL 6E9-428358 - 6E9-431767 1988
40 ELT 6E9-502266 - 6E9-503090 1988
40 M 6E9-009891 - 6E9-016060 1989
40 ML 6E9-314464 - 6E9-352310 1989
40 M 6F6-018405 - 6F6-020316 1989 Marathon
40 ML 6F6-332945 - 6F6-338026 1989 Marathon
40 E 6E9-106224 - 6E9-150385 1989
40 EL 6E9-431768 - 6E9-452215 1989
40 ELT 6E9-503091 - 1989
40 M 6E9-016061 - 6E9-016785 1990
40 ML 6E9-352311 - 6E9-355080 1990
40 M 6F6-020317 - 6F6-023805 1990 Marathon
40 ML 6F6-338027 - 6F6-343435 1990 Marathon
40 E 6E9-150386 - 1990
40 EL 6E9-452216 - 1990
40 M 6E9-016786 - 6E9-018005 1991
40 ML 6E9-355081 - 6E9-358040 1991
40 M 6F6-023806 - 6F6-025689 1991 Marathon
40 ML 6F6-343436 - 6F6-350151 1991 Marathon
40 M 6E9-018006 - 6E9-018725 1992
40 ML 6E9-358041 - 6E9-359705 1992
40 M 6F6-025690 - 1992 Marathon
40 ML 6F6-350152 - 1992 Marathon
40 ELO 6E9-454001 - 6E9-454360 1992 Sold Japan only
40 ELO 6E9-453891 - 6E9-454360 1992 Sold intnl & Canada only
40 EO 6E9-151006 - 6E9-151090 1992
garethdeb
That's excellent, many thanks for that. Yes, apparently it is probably a Yamaha built engine from somewhere during the eighties. It's a two stroke, twin choke, pull start engine. I've got a parts catalogue on disc which I'm using to try to identify which engine it is but there's so many. I was coming to the conclusion it was a 40M 676A but the A exhaust was above the prop whereas mine exhausts from the prop which suggests a B. Also looking through the drawings mine has a single block coil pack whereas the drawings for these models shows it as two separate units.
Maybe I would be better off following down the Yamaha route, I just never realised Yamaha used to build for Mariner for Europe (I'm in the UK)
Anyway, many thanks indeed for all the help.
Gareth
