natemoore
- Joined
- Jun 13, 2009
- 844
I got curious about the state of my lower unit lube after a several trips out onto Santa Rosa Sound. Milky oil!
I pulled the outdrive. No water or oil in the u-joint bellows. Short shaft seal is good.
I pressure tested the unit assembled. Saw bubbles coming out of the exhaust hub and up around the water pump. So I pulled the upper and lower unit apart and pressure tested individually.
Upper unit held 10 psi (highest on my gauge) for an hour w/o the loss of any psi. No soapy bubbles either.
Next, I tested the lower unit. No bubbles anywhere around the water pump. So, it appears that the leak is coming from somewhere in the propeller shaft housing. I did all the re-sealing myself except for the prop shaft seal since I didn't have the expensive tools needed. The one thing I "hired out" wasn't done correctly.
Take a look at the pictures. I think this is the carrier assembly down at the bottom where the bubbles are. It looks like I either have a cracked carrier assembly or the large o-ring at the back of the carrier is bad? If I'm able to fabricate a wrench to remove the retainer nut, can I just pull out the carrier and replace the seal and o-ring?
Just need a little help here. Promised my 14 year old daughter I'd take her fishing for redfish in Pensacola Bay soon.
Thanks
Thanks
