1986mariner150
- Joined
- Mar 13, 2004
- 142
Hi and thanks for looking at my post. I have just got home with a new battery charger from walmart.<br />It is a schumacher speed charge, computer smart. I must say I am pretty impressed with it so far. It tests as well as charges, has a digital volt meter built in that read volts,or percentage of charge or percentage of alternater output. The manual says it hits it at first with as many amps as it can handle then levels off till the percentage gets to 100 then switchs to a maintenance mode. Also has automatic desulfate cycle when it detects you need this. All for $40. <br />They also have a less amperage model with all the same features for $25. I have been considering onboard charger for the boat for a while now and was told that other than the multiple output banks the other main difference was the way they switched to different charging rate to maintain peak power. I am wondering if the technolgy is the same and if 2 of the $25 units left plugged in 24/7 would be safe and as good as an onboard? I forgot to mention above there is a deep cycle setting.
