Hi Guys...Ran a search on my problem before coming to the board with it. 1977 OMC 5.7 litre with Electric shift drive. Tilt was working perfectly (as perfect as they get). Before heading to the lake, I double checked it and all I got was the dreaded click of the solenoids. Checked all the connections first. You could hear the click in the drive as well, so I assume I'm getting power all the way down. Removed the worm gear and shaft, no spin on the motor. Took the motor out, cleaned it up, reinstalled and it worked like a charm. Out on the water having a grand time. Comes time to raise the drive and we're back to square one, just a click. Won't raise when you try to help it by hand. Is something binding up causing the shaft not to turn? Any help appreciated.
