I have an intermediate Tachometer, works sometimes, does not work others. There is no rhymn or reason, at idle everything will be working and all of a sudden the tach drops to zero, shift into gear and everything works fine again.
I got the procedures for testing my rectifier, would a bad or dying rectifier cause this? All the connections seem tight, no corrosion. According to my new depthfinder, the charging sysem is working.
I an not real concerned about the tach, but I am trying to dial in the setup and without a real rpm number you are just guessing at performance.
Thanks for the tips,
Ginder75
Ginder75
