Yet another winterizing question
spdracr39
I found only 4 plugs to drain the water on my merc. One on each riser and one each side of the block. I traced the power steering lines from the pump to the rack and don't seem to have a cooler. Is that it?
Alpheus
Re: Yet another winterizing question
You should have a power steering cooler.
Here are links to the OEM service manuals you need just in case you dont have them...
Outdrive Manual
Engine Manual
