Yielding to the Power
Texasmark
Ok you guys. <br /><br />Back when I joined this forum, after just buying this used boat, you told me to keep my stat (which I had removed because the old one stuck closed) and decarb (de what? had never heard of it). Well I resisted and finally, after a couple of months of membership I realized that you guys were in the know.<br /><br />The stat has been back in for two trips out now and the decarb has had almost 2 months to do it's handywork....added it to the fuel, didn't do the crash cleanout.<br /><br />So I was out yesterday...course the weather is considerably warmer than when I started, but none the less, she is (initially) starting much easier and idling much smoother...course I'm coming down from a I6 Merc to a 3 so there's a learning curve there too. <br /><br />After stopping off at a fishing hole and moving on, it restarted every time with just a turn of the key at idle. That's the way it's supposed to work.<br /><br />Thanks,<br /><br />Mark
Texasmark
Re: Yielding to the Power
Well I would have certainly surmised that one of the big dogs would have hopped off the porch and jumped on this freebie. Well, maybe not.<br /><br />Mark
tashasdaddy
i didn't listen at first. but after about $1000.00, i learned to listen and do it the right way. thats was on the i/o forum, my 1st and last i/o.
Texasmark
My only I/O was nice and quiet; except in turns where the CV joint rattled but it just had those inherent problems (not mechanical per se) that made it more of a nuisance than an asset.<br /><br />Mark
