I just purchased a 2000 Zodiac YL275R.On 1 of the tubes when I remove the outer valve cap the tube deflates(rapidly) while on the other side I have to push in on the spring loaded inner valve to deflate the tube.The troubled valve seems to be spring loaded like the other side and I see no visible difference between the 2.The tube seems to hold air with just the outer cap but I just don't trust the valve.The seller was selling the boat for a friend so had no knowledge about the boat.Also no pump came with the boat so any suggestions would be greatly appreciated.
Thanks in advance.
Thanks in advance.
