yoke problems on volvo
captpgn
'99 volvo sx :Just been informed that my u-joint bellows was found to have gear lube inside due to a faulty yoke seal. They said the yoke was cracked and a replacement was around $400. Is that a fairly accurate price? Having been extremely careful with this outdrive (idle rpm's only when outdrive had to lifted for shallow water). No undue stress was ever put on the unit. I was very surprised this has occurred. Any thoughts on this or questions I should have with this diagnosis? Any attention to this would be appreciated. captpgn
Re: yoke problems on volvo
Ayuh,... Never seen 1 Crack before,...
They tend to Wear where the seal rides, causing the oil in the bellows thing...
captpgn
Thanks Bondo. Any knowledge on the $400 price tag.
rodbolt
no yokes,crosses or input shafts avalible from volvo for the SX, the shaft assy is about 379 sitting on the counter and comes with a new bolt and crush sleeve.
takes about 2 hours to change the shaft assy if the unit is already on the lower unit stand.
you will also need a new seal and an input bearing box oring.
sierra does make an assy but the only two I tried took extensive work with a needle file to deburr the splines sufficiently to allow the yoke shaft to fit the splines on the driven gear.
wont try a third time.
zbnutcase
I used a Sierra one once and it fit perfectly. Maybe I got lucky...
captpgn
Hey Rodbolt ,Zbnutcase have either of you seen any that had cracked or just worn out as in Bondo's accounts.
boat127
i have never seen or heard of one crack. if i were you i would request to see it personally. if its jsut a groove worn in and you put in a speedy sleeve
captpgn
I intend to a inspect when I can get up to the repair shop. What's this speedy sleeve? Is it an effective option and provided an a quality seal? Thanks captpgn
Bt Doctur
google "speedi sleeve"
items like this for repairs
