After replacing the oil seal in the drive shaft housing and after reassembly, I have about .006 end play in the drive yoke shaft. Is this typical? I torqued the yoke nut to specs of 7 lb. in. and the bearing spacer was moving<br />freely as called for in the Merc Manual. The ring nut is also torqued properly. I dont find any reference to end play in the manual. <br /><br />96 Bravo III<br /><br />Thanks
