JoeW
- Joined
- Nov 8, 2003
- 664
From Claims Canino<br /><br />
From Ed Mc<br />You gotta practically FLOOD those to start them. Pump the ball till it's hard, and then a little more to force some gas past the float needles.<br /><br />Slightly advance the idle throttle lever and hold the choke ON while cranking. Once it touches off -bump the choke a little till it catches fully.<br />
I took your advice above left on another thread. My 1988 100 hp Merc started on the first crank this morning. It's never done that on a cold engine before. <br /><br />Thanks guys!Another thing that helps is to have the motor tilted back such that any fuel in the carb throats runs "downhill" into the motor, instead of running out the front. When you do as Clams described, pumping the bulb hard and blowing it past the needles, you're effectively "priming" the motor, just like later models without choke shutters and a primer.<br />
