Z150TRXA
firedog654ibew
Hi, Please what does “ oil pump low “ mean. My software does not explain it. Also not issues when I have my PC hooked up to my motor but it seems to shut down at low RPM as of low fuel to motor. I have to re prim fuel to motor to restart
Many Thanks, Steve
99yam40
maybe you are thinking oil level low not oil pump low..
sounds like the lift pump is not keeping the VST full at low RPM.
restriction or sucking air
that pump may not run all of the time at low RPM
firedog654ibew
Thanks I’ll pull the oil line from the VST to check oil flow
99yam40
I forgot about that small oil pump to the VST.
no idea what and when it runs
by the way I was talking about fuel pumps before
