zerk fitting
algi
not sure if part of a broken zerk went into motor shaft
how bad am i in trouble
thnks
Grub54891
Ditto and what zerk fitting?
Grease fitting in my parts. As in I need a new zerk fitting for my truck.
I'd gander to say the head broke off, and the threaded part fell inside of the lower unit housing...
zerk on a yamaha outboard motor shaft
Yamaha makes motors from 2hp to 350hp and has been doing so for decades. Each motor has 4 shafts (tilt, pivot, vertical, prop)....... Help us help you
Specifically, what motor, what year, which shaft, got a pic?
Grub54891
*Most* outboard housings are just that, a housing. The only thing spinning in there is the driveshaft, everything else is covered. IF any remnant's made it down to the lower unit, they would just lay there till it's serviced next time.
However, IF the threaded part of the zerk went in to the section that gets the grease, it could damage a bushing or bearing.
Was it a threaded zerk, or a pressed in type? I've seen the pressed in ones just pop out before.
algi
the zerk that the wire gets attached to threaded zerk
3rd one down on left side
GA_Boater
The answer is still no. The fitting has no place to fall into. Check your grease gun if it broke off while greasing.
algi
so what u r saying is i should be ok
right
got the new zerk in
will grease in am
if anything got in there it is just small pieces
