ESGWheel
reacted to
racerone's post
in the thread
Safety Equipment
with
Like
A passenger that knows how to start the motor.----Operate the controls.-----Knows how to operate / use the VHF.----Knows location / use...
Yesterday at 7:35 PM
P
parsenault
replied to the thread
Penta V6-280 alarm in with DTCs 1155 and 1157
I figure the O2 sensor was the canary in the coal mine because this particular type is so sensitive to small changes in voltage. From...
Yesterday at 7:31 PM
A
airshot
Spark plugs for a Merc outboard
I looked these up, the -2 means a larger gap for higher output spark but also requires a bigger charge to the plug.
Yesterday at 7:24 PM
Bob_VT
reacted to
Pmt133's post
in the thread
Loosing Faith in Humanity . . .
with
Like
I've sold a few things on market place. Lots of interest but few hits. Got 2k for my old 3.0l within a week of listing. But had a set of...
Yesterday at 7:22 PM
R
Safety Equipment
A
airshot
Wakeboat bans
In my youth, I had a 10' Jon boat and always out running around on the river. Also worked at the local marina, mowing grass and dock...
Yesterday at 7:19 PM
Spring replacement?
They make plastic spring bushings. 1/2" id, 9/16 and 5/8 od
Yesterday at 7:15 PM
A
airshot
reacted to
Mc Tool's post
in the thread
Wakeboat bans
with
Like
"Tapping your toes ".......to Black Sabbath ,Judas Priest and AcDc 😁there is something wrong with you Jimmbo😂😂 Id rather listen to the...
Yesterday at 7:13 PM
H
Hatch19
lower shift shaft positioning for gear selection
This was the answer. Thank you!! Issue obviously occurred when I split the lower off. Messed with it today and 30 mins later now...
Yesterday at 7:08 PM
Augoose
reacted to
Lou C's post
in the thread
Volvo Penta 5.0 GL PWTR - severe overheat - thought I was on fire - troubleshooting Questions
with
Like
I think your temps are normal except for the manifolds & elbows, I think thats higher than it should be…my Cobrs has the same Volvos...
Yesterday at 7:01 PM
Augoose
Thanks Lou. The impeller is new and the muffs fit very tightly. Three weeks ago when we tested the boat in the water (when head gaskets...
nola mike
Spring replacement?
This thing is kicking my ass. Finally figured out that the original springs were open eye on one side. Found only a couple of places...
M
Mc Tool
I thought the suffix number was a reference to the gap as supplied. 2 = 2mm gap . Just looking at the ngk plug ref chart .🙂
Yesterday at 6:59 PM
nola mike
For those of us who tow our boat, do you inspect it ?
Yeah, I should. In the midst of a debacle. My leaf springs COMPLETELY fell apart. While in the midst of the repair, noticed that the hub...
Yesterday at 6:53 PM
tpenfield
Interesting that the batteries were causing those codes. I'd give it some time before you do a victory dance though . . . On my 2016...
Yesterday at 6:36 PM
