  • C
    carlos515 replied to the thread Bravo 1 transom plate.
    Thanks, I was just asking as I have a Gen 2 Alpha transom plate and contemplating getting a Bravo 1 outdrive assembly.
  • C
    Hi all, I have a new 2023 mercury 15 efi electric start longshaft. Made in 2023 but bought it new in November 2024(old new sotck) it...
  • Bondo
    Bondo reacted to alldodge's post in the thread Mercruiser Neutral Safety Switch? with Like Like.
    Removed the fuse and cable, reinstalled and it started to work but has issues Remove all the cables from Bat to starter including the...
  • B
    bigbadchevy89 replied to the thread 1988 candia 180 4.3.
    Thanks everyone. All great information. I wasn't able to bring it home this weekend from the lake so unfortunately I'm at a stand still...
  • Lou C
    Lou C replied to the thread 1988 candia 180 4.3.
    On these the timing is set very conservative, 6* BTDC but with 89 octane fuel, with 87 you’re supposed to set it at 1* BTDC. Centrifugal...
  • Scott Danforth
    No. I would first look if your existing manifolds and risers are rusted thru (acetone test) and diagnose what is needed
  • Scott Danforth
    Scott Danforth replied to the thread 2014 GMC Sierra AC.
    Both the vac pump and AC compressor have a stretch belt. My personal favorite stretch belt tool is 2 zip ties and a remote bump start...
  • alldodge
    alldodge replied to the thread Bravo 1 transom plate.
    Transom plates could be, would need to look closer, but the Transom Assemblies are not
  • tg3690
    tg3690 replied to the thread Reeds?.
    Sound advice for sure.....(y)
  • H
    Harkonnen replied to the thread 2005 J115PLSOR weird oil leak.
    It's just that, one, there is nowhere for the stuff to come from but the crankcase (and if it does, why it is pooling in there?), and...
  • matt167
    matt167 replied to the thread 2014 GMC Sierra AC.
    I think 2014 will have the stretch belt. You’ll need a new install tool if you don’t have one, and a 24mm w/ breaker bar to rotate the...
  • E
    If it were your boat would you just take the gamble and buy the taller risers?
  • T
    tphoyt reacted to FLATHEAD's post in the thread New Winch or Winch Strap? with Like Like.
    I bought a boat off an old woodworker/ tinkerer once. He had a elcheapo 12 volt ATV style winch mounted to a piece of hollow steel...
  • C
    Would an Alpha 1 gen 2 transom plate be the same as a Bravo 1?
  • alldodge
