redneck joe
replied to the thread
New Winch or Winch Strap?
See post #35
Jul 21, 2025
M
MikeSchinlaub
reacted to
BWR1953's post
in the thread
It rained on my fresh, wet paint!
with
Like
:ROFLMAO::ROFLMAO::ROFLMAO:
Jul 21, 2025
aspeck
reacted to
airshot's post
in the thread
with
Like
If it was an enamal, just let it finnish drying, you might end up with a slight dimple mark from the rain drop but should not be an...
Jul 21, 2025
aspeck
reacted to
BWR1953's post
in the thread
with
Like
What to do? The only thing I can think of is to let it dry, then deal with it after that. I did catch it quickly. Any other thoughts?
Jul 21, 2025
BWR1953
Jul 21, 2025
D
Donald0039
Volvo/OMC Raw Water Pump Repair/Replacement
You can pull the old pump. Then pull the seal and look and see if the shaft is worn where the shaft seal seals the pump. If there is...
Jul 21, 2025
Tensioner Replacement
you can get replacement idler pulleys by themselves, however in most cases its nearly the same cost.
Jul 21, 2025
D
Donald0039
I just ordered a new one as my current one has more of a "harsh bearing" noise than the idler when listened to using mechanic stethoscope.
Jul 21, 2025
R
Rhadley
alpha 1 won't go into reverse
did you figure this out? I have the same problem. The slack measurement on the lower shaft is slightly high (.59 vs .56). I can push the...
Jul 21, 2025
T
tphoyt
reacted to
Scott Danforth's post
in the thread
with
Like
Wisdom comes from experience.....experience comes from mistakes and bad decisions.
Jul 21, 2025
ratdude747
MC-1 Drive Dog failure?
I just don't want a failure on the water or to destroy the rest of the drive. Although given what I know about my lower (possibly...
Jul 21, 2025
M
MikeSchinlaub
reacted to
in the thread
with
Like
Jul 21, 2025
G
Gerhard Peters
Posible oil and water mix in mercruizer sterndrive
Do you mean in the system for trimming the outdrive? I have oil mixing in the gearbox not the trimming system if that is what you mean
Jul 21, 2025
Your old motor is not a HP big boy so using your old gears does not concern me, but this is your money and not mine I would rebuild the...
Jul 21, 2025
ratdude747
The other case the guy offered for free (was $100). It's just a long 4.5 hour drive away. Clearly an older one since it has the older...
Jul 21, 2025
