B
beardedturkey
replied to the thread
Where does the hose go?
This is the info Evinrude Outboard 1994 120 E120TLERC
Jul 22, 2025
N
Nordin
90hp outboard died suddenly, wouldn't restart
This engine suppose to have three ignition coils one for each cylinder. Seams odd if all three coils will go bad at the same time. Check...
Jul 22, 2025
N
Nordin
1955 Evinrude Fleetwin 7.5hp carb kit?
Fleetwinner the compression numbers are also important. These small engines should be in range 80-120 PSI maybe higher, but most...
Jul 22, 2025
l008com
Update: i did some testing today. First I pulled the plugs, they were wet (so no fuel clog) and they were in pretty good shape aside...
Jul 22, 2025
S
searay250
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
Haha yeah, I definitely confused things with my "custom" numbering! My suspicion is that when I go to match up the wires with your...
Jul 21, 2025
W
wjhuskey
How to restore this 1961 hull?
Yes mine had balsa wood in it too and it was rotted... the fiberglass shop put in marine plywood when they replaced the floor. They had...
Jul 21, 2025
S
saltchuckmatt
2005 J115PLSOR weird oil leak
If that crank seal was bad you'd have running issues. I think you need to go run that motor hard somewhere. Burn it out.
Jul 21, 2025
T
tphoyt
question on the starting a "2 cycle Merc" sticky
Yeah and you could fix all that stuff in your driveway or even the side of road. Now days it takes hours and big bucks to get to...
Jul 21, 2025
Rranger
reacted to
Scott06's post
in the thread
1972 Mercruiser 165.
with
Like
is this the procedure ...
Jul 21, 2025
jimmbo
My first 3 cars had the Floor Stomp Dimmer Switch; 66 Ford Galaxie, 71 Buick Skylark, and 76 Olds 88 Royale. I remember the Foot...
Jul 21, 2025
J
jststrd1
posted the thread
Throttle movement but no increase in engine rpms
in
Mercury MerCruiser Sterndrives & Engines
5.7 Vortec 4 barrel Rochester alpha one gen 2. 2000 2352 Trophy I was out last week and noticed that I get to a point with my throttle...
Jul 21, 2025
H
happychapboater
posted the thread
4.3gxi bad temp sensor?
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
I’ve been having issues with one of my engines in that it is stalling at idle and sounds like it’s searching. I just got the tech mate...
Jul 21, 2025
dingbat
New sea pump front seal walking out. Causes? Fixes?
Seals can walk for any number of reasons: Not properly seated Wrong size seal Out of tolerance housings and or seals Bent shafts Bad...
Jul 21, 2025
ESGWheel
Oh, the great news is the compression numbers! You have a solid engine but I am concerned about the black plugs that indicate its...
Jul 21, 2025
ESGWheel
No you are correct. I missed that this was your unique wiring system. Yes, the front of the boat is front of vehicle. This just goes...
Jul 21, 2025
