R
replied to the thread
2005 J115PLSOR weird oil leak
It should be easy to find this leak in my opinion.-----But I can not touch this motor.
Jul 22, 2025
S
searay250
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
Ooops! Yes, good catch... I meant: 1) I feel like I have very fast consistent spark off the coil.... 2) Yeah when I sometimes DO get...
Jul 22, 2025
H
Harkonnen
Probably not, the block is clean all the way down. The seal and driveshaft are right there, and there seems to be just enough of an...
Jul 22, 2025
JimS123
Kicker motor vs towing
Not necessarily. My last boat had an I/O with a built in tank. My 9.9 2-stroke used a separate 6 gal portable tank, stored under a...
Jul 22, 2025
H
Harkonnen
I'd rather have it come off than have the crank seal blown.
Jul 22, 2025
JimS123
If you boat in small bodies of water with little current, have a cellphone and know that there are boaters that can help you, and/or...
Jul 22, 2025
JimS123
Calm winds, mid day Friday, full sunshine, the morning weather report said seas less than a foot. At the launch ramp the VHF weather...
Jul 22, 2025
FLATHEAD
daily music fix
Rip ozzy https://g.co/kgs/agXyRiQ
Jul 22, 2025
ESGWheel
These sentences appear to be conflicting. Recall you need the snap, snap, snap rapid fire off the coil, less so off the spark plug wire...
Jul 22, 2025
S
searay250
First off, I might be a hostile witness.... I would consider it more like an "accidentally ignorant" witness but I think the end result...
Jul 22, 2025
ct1762@gmail.com
J90ELEDR Cooling Concerns
how are you checking head temp? that alarm will go off right around 240f, which prompts me to swap the tan/blue sensors with the earlier...
Jul 22, 2025
H
Harkonnen
It IS, if it (partially) fills with liquid.
Jul 22, 2025
Grub54891
posted the thread
Ozzy Osbourne
in
Dockside Chat
https://www.yahoo.com/entertainment/articles/ozzy-osbourne-black-sabbath-frontman-181737802.html
Jul 22, 2025
Scott06
yeah why use the spark gap tester he already owns when you can become the path to ground.
Jul 22, 2025
Scott06
Look for signs of arching in the cap, also if you get spark into the cap and not out of cap to plugs or wires. Just the gap tester you...
Jul 22, 2025
