R
replied to the thread
How to restore this 1961 hull?
I have used 1-1/2 plastic pipe cut in half.-----Used to make ribs / stringers.-----The fiberglass is laid over the pipe to give it the...
Jul 22, 2025
Rear water port near deck
Most likely added by the prior owner. Agree with AD, missing the check valve and cap
Jul 22, 2025
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
Ted, the rule of thumb with motors. 1/3 the fuel goes to turning the crank, 1/3 goes to heating the block, 1/3 goes to heating the exhaust
Jul 22, 2025
A
airshot
Kicker motor vs towing
Very true....I have used the cheap tracfones for years...many years ! One reason is, I get thru when no one else can. No reason why...
Jul 22, 2025
A
airshot
reacted to
JimS123's post
in the thread
with
Like
Not necessarily. My last boat had an I/O with a built in tank. My 9.9 2-stroke used a separate 6 gal portable tank, stored under a...
Jul 22, 2025
A
airshot
reacted to
JimS123's post
in the thread
with
Like
If you boat in small bodies of water with little current, have a cellphone and know that there are boaters that can help you, and/or...
Jul 22, 2025
G
GongshowBayliner92
1992 18ft Bayliner Capri restoration
Well, still atter. Painted, floor is done, just bulk heads, seats, sides and front seats to do, glass it in and fill with foam then foam...
Jul 22, 2025
BWR1953
1997 Mirrocraft 18' aluminum fish n ski
Got the console paint job finished. Sprayed the last coat of blue on the console this morning. Worked nicely. And I bought some...
Jul 22, 2025
C
cyclops222
reacted to
DeepCMark58A's post
in the thread
with
Like
I have a cell phone if I break down, my neighbor owes me a favor I brought him out gas last week when ran out on his pontoon.
Jul 22, 2025
tpenfield
I could temperature probe it fairly easily . . . not sure about measuring the flow. In other news . . . I drained, neutralized, and...
Jul 22, 2025
T
tphoyt
reacted to
FLATHEAD's post
in the thread
cooking
with
Like
It was. No seasoning whatsoever. Seared at about 450* turned down the heat, cook till it’s 140 internal. Slap it on a plate.
Jul 22, 2025
tpenfield
90hp outboard died suddenly, wouldn't restart
Maybe it 'works' and killed the engine. You could exercise the switch to see if it makes a difference.
Jul 22, 2025
FLATHEAD
cooking
Jul 22, 2025
C
Cap Doug
reacted to
alldodge's post
in the thread
with
Like
My guess is the boat use to be in salt water and that is a fresh water flush port. It's probably missing a cap
Jul 22, 2025
Jul 22, 2025
