redneck joe
posted the thread
Jimmys boat
in
Dockside Chat
https://robbreport.com/motors/marine/jimmy-buffett-explorer-yacht-auction-1236895174/
Jul 23, 2025
N
Nordin
replied to the thread
90hp outboard died suddenly, wouldn't restart
I am not very familiar with these engines but you maybe have two stop possibilities. Keyswitch to stop (left position of the key) and...
Jul 23, 2025
tpenfield
2006 5.7L Mag Overheating
I didn't see this info in your other thread . . . Salt water or fresh water? Raw water cooled? or Closed cooling? Last time the...
Jul 23, 2025
tpenfield
reacted to
Fun Times's post
in the thread
with
Like
The black fitting on the red water hose is a quick disconnect coupler… it does need to be seated correctly as there is an O-ring in...
Jul 23, 2025
jimmbo
Throttle movement but no increase in engine rpms
On a Q-jet, the Secondary Throttle Shaft/Plates are moved/opened by the Throttle Linkage. An Air Valve above it is what allows Airflow...
Jul 23, 2025
jimmbo
Airflow Sensor? The Air Valve over the Secondaries, is opened by the Pressure Differential that is between above and below it. It is...
Jul 22, 2025
B
BOYS & TOYS
reacted to
BWR1953's post
in the thread
1997 Mirrocraft 18' aluminum fish n ski
with
Like
Got the console paint job finished. Sprayed the last coat of blue on the console this morning. Worked nicely. And I bought some...
Jul 22, 2025
B
BOYS & TOYS
reacted to
MNhunter1's post
in the thread
1972 Starcraft Nova
with
Like
Here are a few pictures from my bow reconstruction:
Jul 22, 2025
B
BOYS & TOYS
reacted to
captainnate's post
in the thread
1972 Starcraft Nova
with
Like
I cut a new piece of plywood for the dash, but I couldn't get it wedged in there, so took of the front section of aluminum sheet. Of...
Jul 22, 2025
B
BOYS & TOYS
reacted to
Moserkr's post
in the thread
198x SS-150 rebuild
with
Like
Air or electric stapler is worth every penny!! I went air. Whats next on the list?? Build starts moving fast when the floors go in.
Jul 22, 2025
J
jststrd1
2 weeks prior had it out with aluminum prop 4300 RPMs. It runs great starts right up even after sitting. I am going to switch back the...
Jul 22, 2025
H
happychapboater
4.3gxi bad temp sensor?
Just throttle and IAC I’ve tried swapping. IAC position is 120. 5v for both were 4.7-4.8v with engine off, key on. Tech mate shows map...
Jul 22, 2025
B
bheston
posted the thread
2014 mercury 115hp EFI 4 stroke running rough, lack of power
in
Mercury & Mariner Outboards
I've been troubleshooting issues with this engine, and found a problem with the low pressure fuel pump and have that fixed. On my test...
Jul 22, 2025
R
RMassa187
Alpha Gen 2 Stalls Going to Neutral (Shift Cable Replaced)
The switch is centered in the notch. Everything moves smoothly and easily by hand. Original shift plate and switch. The switch seems to...
Jul 22, 2025
Fun Times
Jul 22, 2025
