replied to the thread
Throttle movement but no increase in engine rpms
This doesn't add up, 4 blade aluminum to 4 blade stainless and same pitch. Maybe if the aluminum was damaged
Jul 23, 2025
Scott06
4300 is still low for that engine should be 4800 -5k at WOT. If you go in shallow water lift the drive up would think you can swap...
Jul 23, 2025
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Jimmys boat
with
Like
its just one of many of Jimmys fleet of boats. he also had a Westport that was being serviced down at Rybovich, and about 5 in the...
Jul 23, 2025
4.3gxi bad temp sensor?
Good point, have motor running
Jul 23, 2025
H
happychapboater
The IAC on the good motor was showing 130 for the value with key on, ignition off.
Jul 23, 2025
C
cyclops222
Kicker motor vs towing
I keep remembering a terrible wind storm that flipped over loads of pontoon boats on a southern lake. Many drowned. I bought the 19'...
Jul 23, 2025
Grub54891
reacted to
beardedturkey's post
in the thread
Where does the hose go?
with
Like
Something is already attached to the air box. A slightly smaller hose.
Jul 23, 2025
nola mike
Alpha Gen 2 Stalls Going to Neutral (Shift Cable Replaced)
The spring can be bent to change its tension. The shift plate and cables can also bind.
Jul 23, 2025
Sylva-Ranger
posted the thread
Merc 115 4 strokes 2001 ECU/fuel pump problem
in
Mercury & Mariner Outboards
Merc 115 4 strokes 2001 S\N 0T340811 (Yamaha engine) Hi everyone, hi have problem whit this engine The hi pressure fuel pump run...
Jul 23, 2025
Motor of voltage for TPS looks good, MAP is a bit low, should be closer to 4.9 but 5V ref is a tad low Once started the MAP should be...
Jul 23, 2025
C
cyclops222
reacted to
airshot's post
in the thread
with
Like
Very true....I have used the cheap tracfones for years...many years ! One reason is, I get thru when no one else can. No reason why...
Jul 23, 2025
Ayuh,..... Welcome Aboard,...... Alphas should be shifted, Briskly,.....
Jul 23, 2025
redneck joe
reacted to
in the thread
Jimmys boat
with
Like
Jul 23, 2025
C
cyclops222
Being forced to run into windy wave heights. Are really the limiting factor. I have loads of islands with small private docks all around...
Jul 23, 2025
C
cyclops222
reacted to
airshot's post
in the thread
with
Like
Again, depends on where you boat and what typical conditions are. When I had my Islanders I had a 9.9 kicker on an adjustable transom...
Jul 23, 2025
