reacted to
alldodge's post
in the thread
Throttle movement but no increase in engine rpms
with
Like
That's the diameter, pitch is 18
Wednesday at 11:53 AM
replied to the thread
Im thinking the pitch/diamter is backwards on the OP's statement. aluminum is 14-1/2" dia, 18P and the SS is 15-1/4" dia, 18p the...
Wednesday at 11:52 AM
reacted to
Bt Doctur's post
in the thread
Lost All Steering on Bravo 3 Outdrive
with
Like
be smart to add a grease fitting too
Wednesday at 11:51 AM
reacted to
tpenfield's post
in the thread
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
with
Like
Here are my recordings from this morning . . . Since I did the Port engine first yesterday, I started with the Starboard engine today...
reacted to
Scott Danforth's post
in the thread
fuel leak from infloor tank
with
Like
the hoses could have deteriorated, the new hoses are more tolerant of E10 than the hosed that were in your boat 35 years ago, however...
Wednesday at 11:48 AM
reacted to
Njsloans1's post
in the thread
with
Like
Do you have an aluminum or plastic tank? My old boat had an aluminum tank and where the fuel pickup bolted on, the tank completely...
Wednesday at 11:47 AM
1985 Century Mustang
I have to do a gimbal bearing and bellows etc, I have a question regarding the shift cable. Merc A1 G1 3.0
Bump
rolmops
Kicker motor vs towing
I'm thinking that in this case the word "towing" is really used instead of "trailering". Whether you are towing a boat in the water with...
Wednesday at 11:46 AM
jimmbo
The Al was 14 1/2 and the SS was 15 1/4 Don't know if the AL was cupped, or, actually anything about it. If the AL was already at or...
Wednesday at 11:19 AM
C
cyclops222
VP SX drive low oil but no sign of leak
No oil sheen on the water ?
Wednesday at 11:09 AM
Scott06
Alpha Gen 2 Stalls Going to Neutral (Shift Cable Replaced)
would also pull the drive to make sure the shift swivel shaft and linakge in bellhousing is not corroded or packed with debris causing...
Wednesday at 10:59 AM
C
How to restore this 1961 hull?
The balsa coring in my Crestliner was 1X2 strips laid on the bottom of the hull fiberglass "skin", giving it fore-aft strength, and some...
Wednesday at 10:41 AM
S
sdreinell
posted the thread
Volvo penta trim relay issue
in
Electrical, Electronics, Audio and Trolling Motors
Working on my Volvo Penta 5.7L GL and I'm having some intermittent issues with my trim relay. I'm getting a clicking noise even when not...
Wednesday at 10:29 AM
swift1
I did not do pressure test but I'll go ahead and add more. 2.1 litres is the recommendation for the SX though, so I'm thinking there...
Wednesday at 10:23 AM
