C
cyclops222
replied to the thread
simpli safe
deleted
Thursday at 7:28 AM
H
helix757
Problems starting after fuel filter/water separator change
Thanks for the reply! I am leaning towards the need to bleed air. What does the HP bleed port look like? If it doesn't have one, do I...
Thursday at 7:23 AM
MNhunter1
1984 115hp TOP Switch Box Wiring
Are the switch blocks grounded via the mounting screws? Do they need a separate ground wire? Any potential harm/damage if I try to...
Thursday at 7:22 AM
IslandExplorer
reacted to
ab59's post
in the thread
Transom replacement 1975 18' SS
with
Like
Well, first off, thanks for all the replies!! I was hoping ( but somehow knew it wasn't going to be) this would be a quick job that I...
Thursday at 7:17 AM
MNhunter1
1972 Starcraft Nova
Yes, the rivets should drill out like any other rivet. I don't recall it being difficult to put back together, but I only replaced my...
Thursday at 7:13 AM
B
BRICH1260
VP SX drive low oil but no sign of leak
Always fill until it flows from the upper side vent screw hole. It is possible that you could have a driveshaft seal bad and that the...
Thursday at 7:13 AM
Grub54891
simpli safe
Following as I've been thinking about that also.
Thursday at 7:12 AM
redneck joe
posted the thread
simpli safe
in
Dockside Chat
my 82 year old dad has three houses he rotates between, primary got hit the other day. Oddly, only a few things taken, nothing too bad...
Thursday at 7:02 AM
redneck joe
Great loop speed record attempt
yeah he wont break the record as he has barely started around the UP but I'll give it to a 71 year old dude, i'm impressed.
Thursday at 6:57 AM
P
Pmt133
reacted to
redneck joe's post
in the thread
Boat budget question
with
Like
ok, i've purchased all i needed for the rehab so final numbers are in however i have decided to continue tracking all boat future...
Thursday at 6:44 AM
N
Nordin
Electronic distributor made a buzzing sound
Yes, try Bill Kelly and why not Franz Buddenberg at Franz Marine Service. Franz is a Chrysler/Force guru.
Thursday at 6:44 AM
redneck joe
Thursday at 6:30 AM
dingbat
You can’t prime a EFI high pressure pump with air in the system. I’ve tried many different ways of “priming” fuel systems after...
Thursday at 6:27 AM
D
dubs283
On crank no fuel to throttle body mercruiser 305 EFI
This is most likely the culprit. It is called the ignition sensor and located in the distributor, under the cap. It's a hall effect...
Thursday at 6:16 AM
redneck joe
Random
i smoked some trout in a carboard box with a $15 electric stove eye, some bamboo garden stakes and a metal pie pan. Save your money...
Thursday at 6:15 AM
