C
cyclops222
reacted to
Lou C's post
in the thread
I should add a 2nd battery...
with
Like
It’s rare but when that’s happened what I’ve done is start on the battery that wasn’t used for the bilge pump; then switch charging to...
Aug 16, 2025
Lou C
replied to the thread
Aug 16, 2025
C
cyclops222
Excellent logic. There is NO DIFFERENCE going to a boat after enough rain has run down the Starting Battery to 0 volts. Moored out or at...
Aug 16, 2025
K
Kosmofreeze
reacted to
tpenfield's post
in the thread
with
Like
Generally 2 ways of adding an additional battery to a single battery set-up: 1) Directly connected in parallel 2) Selectable via...
Aug 16, 2025
C
cyclops222
reacted to
Lou C's post
in the thread
with
Like
I added the dual battery system with the switch about 20 years ago because my boat has always been moored and if heavy rains & storms...
Aug 16, 2025
WIMUSKY
reacted to
FLATHEAD's post
in the thread
Pigskin Pick’em
with
Like
Hard to believe with all the regulars on this site we can’t get a few more to join in. Got to be a few more football fans here. Not...
Aug 16, 2025
Grub54891
reacted to
redneck joe's post
in the thread
Ozzy Osbourne
with
Like
https://www.facebook.com/share/r/19LLGGCNAY/
Aug 16, 2025
Lou C
Aug 16, 2025
R
Rhadley
Stretched Shift cable. Cut to shorten?
I took off the outdrive and found that the shift cable connection to the slide has a bunch of play. Shouldn't the slide not move unless...
Aug 16, 2025
C
cyclops222
Are you doing the complete installation personally ? Or just wanting enough information to order someone else to do it your way ?
Aug 16, 2025
J
Jeff J
Tell tale not peeing
I grease the heck out of the impeller, cup and base plate. Anywhere rubber is going to rub gets marine grease just like the prop shaft...
Aug 16, 2025
bajaman123
reacted to
FLATHEAD's post
in the thread
are there boat "salvage yards" anywhere in the U.S.?
with
Like
I’ve seen some private properties that if you didn’t know better you’d think they were a salvage yard.
Aug 16, 2025
D
DeepCMark58A
reacted to
aspeck's post
in the thread
Had a heck of a day
with
Like
Don't you just love it when a plan comes together ...
Aug 16, 2025
Texasmark
reacted to
roscoe's post
in the thread
Performance expectations for a smaller boat??
with
Like
Considering a major down sizing for my fishing boat and would like some reassurance that I am doing the right thing. Boat would be a...
Aug 16, 2025
dingbat
Added a second battery with Blue Seas “add a battery” kit. Went with two (2) FLA deep cycle batteries for increased storage and...
Aug 16, 2025
