flyingscott
replied to the thread
2003 Mercury ELPTO won't rev above idle
Is your throttle cable broken?
Aug 16, 2025
S
sinkhole
posted the thread
Retaining ring on1975? Johnson
in
Johnson & Evinrude Outboards
Can anyone tell me which way is up on armature retaining ring (bevel side up or down ) also what is the milled out section for? Thank...
Aug 16, 2025
M
Mc Tool
Tell tale not peeing
My old muffs had gone a bit hard and didnt seal on the lower unit very well . Yep turning them 90 deg may or may not help . My new...
Aug 16, 2025
3
3ric
Thanks for all the advice! I took her to the lake today and it peed just fine. I’ll try some of the ideas including the tape. I...
Aug 16, 2025
K
kenny nunez
Need help finding part number
Do you know the difference between high and low profile upper gear housings? All Ford 351 upper gear housings were low profile. All...
Aug 16, 2025
K
kepruno
2005 4.3 liter Mercruiser ignition trouble
No fuel injection on this model but I think it was available at the time. My issue is for sure spark not fuel.
Aug 16, 2025
A
aidanmurphy
posted the thread
in
Mercury & Mariner Outboards
Hey all looking for a little input on where to start looking first. Went out on the water and cruised for about 30 minutes and the...
Aug 16, 2025
C
Crosbyman
New to me 18 hp Evinrude.
ok looks like simple electrical problem and removing the plate is simple ...remove back corner coil long bolts and 2 base screws to...
Aug 16, 2025
A
airshot
I should add a 2nd battery...
If the bilge pump keeps running the battery down, perhaps a better cover is needed to keep the water out. My 140 ah lifepo4 battery...
Aug 16, 2025
BWR1953
reacted to
redneck joe's post
in the thread
Is it only a matter of time for leaks?
with
Like
We have pics, a water test is worth a thousand pics.
Aug 16, 2025
redneck joe
Aug 16, 2025
K
KD4UPL
Is A I a totally unreliable function ?
In my experience the AI answers that pop up to Google searches (don't know how to turn them off) are maybe 50/50 in being correct. It's...
Aug 16, 2025
B
Bman2895
18 or 25? Anyway to tell?
Ohh it is very sketchy haha. It seems to hold up just fine to the power for now. So I'm gonna ride it out till winter then dig into that.
Aug 16, 2025
jimmbo
The Cowl Cover looks like a 1969(based on the Graphic on the Back of the Cowl) . The Recoil looks like it was from a Johnson Motor...
Aug 16, 2025
J
Jeff J
Is the 2005 fuel injected? We had a newer one do exactly like you described out on the lake. The fuel pump was failing. It was only...
Aug 16, 2025
