P
Pmt133
replied to the thread
A few questions on a new to me 2020 Mustang GT
Could always try a chalk test. Still will get you in the ball park, though I doubt you'll be far off factory pressure on the tires. The...
Aug 17, 2025
Lou C
I should add a 2nd battery...
Agreed I have good covers & always used them even though it’s a pain but the boat isn’t self bailing so you just have to use em. And no...
Aug 17, 2025
BWR1953
reacted to
redneck joe's post
in the thread
Is it only a matter of time for leaks?
with
Like
Oh and as a member of this forum it is requred that you have to let us know which one you ended up with, even if not one of these two...
Aug 17, 2025
ezbtr
door sticker says 32 psi for all with 18" stock wheels, I have 20's
Aug 17, 2025
A
airshot
reacted to
DeepCMark58A's post
in the thread
Had a heck of a day
with
Like
I told myself I am blessed I have two boats to repair and maintain and live on the water. Nice things do not come easy.
Aug 17, 2025
A
airshot
reacted to
DeepCMark58A's post
in the thread
Oil Pressure Sender failure modes?
with
Like
Put a pressure gauge where the sensor is, rig up a t with pipe fittings. See what is really happening.
Aug 17, 2025
A
airshot
Well....pics should be worth at least 100 words.....lol..
Aug 17, 2025
A
airshot
reacted to
redneck joe's post
in the thread
with
Like
Aug 17, 2025
G
Galvez83
Volvo Penta stiff steering
Transom unit TSK SX-M and drive is DP-SM
Aug 17, 2025
dingbat
Aug 17, 2025
nola mike
Shift cable bellows.
ok, I think I see what you're talking about. one of the two items to the left of the gasket here?: https://a.co/d/hiZTmmU
Aug 17, 2025
J
Jeff J
2005 4.3 liter Mercruiser ignition trouble
Should be good then. I can’t think of a better way to check it without a dedicated tester.
Aug 17, 2025
K
kepruno
I did check battery with volt meter while cranking but no load test other than that. I only have an analog volt meter but it did not go...
Aug 17, 2025
redneck joe
Aug 17, 2025
J
Jeff J
Have you load tested the battery to make sure the voltage drop doesn’t start there?
Aug 17, 2025
