Lou C
replied to the thread
99 Volvo 5.0GL
If you have a carb the proper fuel pressure will be on the low end, the 3-8 psi spec you cited. A 99 Volvo for sure won't have points...
Aug 17, 2025
BoatingCop
posted the thread
Fuel Sender Leak
in
Boat Topics and Questions (not engine topics)
I have a 2000 Sea Pro SV1900CC I’m repowering and rewiring. I have a leak where the fuel sender goes into the top of the poly tank. Some...
Aug 17, 2025
K
kenny nunez
Need help finding part number
Those numbers are not the correct ones. Those might be a production date code. 982226 is the # for an empty gear case. This will fit...
Aug 17, 2025
K
kepruno
2005 4.3 liter Mercruiser ignition trouble
Anyone have a diagram of this? I need a map
Aug 17, 2025
K
kepruno
10 pin engine connector visually looks immaculate. Not sure how or what to check with volt meter.
Aug 17, 2025
K
kepruno
reacted to
alldodge's post
in the thread
with
Like
Aug 17, 2025
aspeck
Boat opinions
For PFDs you need to get something comfortable that you will wear. I would recommend inflatables. They are comfortable and not overly...
Aug 17, 2025
R
Reduced speed under load
The motor appears to be a 1975 model.----There was no electric shift on 1975 models.----Make sure carburetors ( high speed jets ) are...
Aug 17, 2025
BWR1953
What is this indicator? (2000 Bayliner)
Depth charge launcher? :unsure: :ROFLMAO:
Aug 17, 2025
Grub54891
reacted to
dingbat's post
in the thread
Oil Pressure Sender failure modes?
with
Like
Aug 17, 2025
guy48065
This dealer-added switch is in addition to the factory 3-position switch? Most things are wired directly to battery on mine, but the...
Aug 17, 2025
aspeck
reacted to
DeepCMark58A's post
in the thread
Had a heck of a day
with
Like
Burned 50 gallons of boat gas yesterday the 3 person tube is destroyed but the boat did not miss a beat. I was a little concerned with...
Aug 17, 2025
D
daf64
Water leaking
I tryed to up load a pic .not working .never came out that area before I did the water pump . Is there an o ring on the drive shaft by...
Aug 17, 2025
D
Drivewayboater2
have you rebuilt the carb? Cleaned it? Checked float level? I’d start there. Simple and easy to do.
Aug 17, 2025
Don't know for sure but my Rinker had a switch added by the dealer. The issue is the digital depth gauge would get messed up, and to fix...
Aug 17, 2025
