M
mike_i
replied to the thread
are there boat "salvage yards" anywhere in the U.S.?
Not exactly a boat junkyard but is the closest thing in my area. http://www.minneysyachtsurplus.com/
Aug 18, 2025
Oil Pressure Sender failure modes?
easy to add.
Aug 18, 2025
Port motor out!
troubleshoot..... do not assume anything. start with fuel pressure
Aug 18, 2025
Port motor out!
Do what Scott mentioned. Can get a loaner tool from auto parts place. Should be 50 to 60 psi
Aug 18, 2025
jimmbo
Can you convert a 20HP Johnny to 35HP with a carb and intake manifold?
Same Displacement does not mean it is the Same Block. Porting may be Different
Aug 18, 2025
jimmbo
Retaining ring on1975? Johnson
If you are referring to a 20hp, it is basically the same as an 18hp. It was made well into the Late 70s.
Aug 18, 2025
R
cowl air inlet on mercury 9.9.
Would that be a 9.8 model?----Serial # is ?
Aug 18, 2025
ingham01952
Port motor out!
At this time, I have switched over all relays and fuses to the other engine to confirm that they are not bad. Everything is working I...
Aug 18, 2025
Scott06
Well yes and no... I think the factory OP switch is tripped at 4 or 7 psi .... so at lower rpms yes it may save an engine but higher...
Aug 18, 2025
nola mike
I have no alarms on the boat, and have been toying with installing some for a long time. if the alarm went off and the pressure dropped...
Aug 18, 2025
aspeck
reacted to
mrschwarz's post
in the thread
Boat opinions
with
Like
I wasn't planning to get one for the kicker. Make sense?
Aug 18, 2025
Scott06
yeah always watching OP and temp. Had an over heat last summer due to weeds on outdrive... had been towing my daughter skiing then...
Aug 18, 2025
nola mike
yeah bored. just curious as to what exactly was causing it to do that. it caused me much angst when the op suddenly dropped while on...
Aug 18, 2025
IslandExplorer
Is it only a matter of time for leaks?
I'd agree with the Super Sport vote, amazingly versatile and convenient layout. That bow area is not to be underestimated! Motors-...
Aug 18, 2025
IslandExplorer
reacted to
redneck joe's post
in the thread
with
Like
Oh and as a member of this forum it is requred that you have to let us know which one you ended up with, even if not one of these two...
Aug 18, 2025
