R
robertw007
reacted to
Scott Danforth's post
in the thread
69' Whaler Nauset
with
Like
Trying to post screenshots of the hull weights
Aug 18, 2025
T
tphoyt
replied to the thread
Boat opinions
My hand held is supposed to be water proof. If it needs to go down with me I guess I’ll find out if it really is.
Aug 18, 2025
IslandExplorer
Is it only a matter of time for leaks?
Aug 18, 2025
7
78 Thompson
posted the thread
Rear main seal 5.7
in
Mercury MerCruiser Sterndrives & Engines
I recently installed a rebuilt engine, a 96 mercruiser 5.7 I installed a Felpro rear seal, after reading more threads on rear seals, it...
Aug 18, 2025
P
Phillip_333
1986 Mercruiser 170 running issue
Is choke opening all the way?
Aug 18, 2025
P
Phillip_333
No Trailer and Trim Up
Okay, trim pump electrical diag needed. Grab a multimeter and check power to up solenoid on the power feed side. Then check switched...
Aug 18, 2025
P
Phillip_333
On throttle up the engine dies
Pull fuel sample from fuel/water separator, and look for corrosion under the distributor cap. Rule those two issues first as they are...
Aug 18, 2025
IslandExplorer
Another great option, considering you aren't bent on bow access being optimized, is the Starcraft Islander series. Esp for looks in my...
Aug 18, 2025
C
cyclops222
Is A I a totally unreliable function ?
It do special effects for the affected.
Aug 18, 2025
C
Crosbyman
BRP outboard old but funny
Old J&E are like the Everady bunny...
Aug 18, 2025
C
cyclops222
reacted to
mrschwarz's post
in the thread
Boat opinions
with
Like
Thanks everyone. I plan to pick up printed charts for the areas I plan to be in. I have added a boat hook to my 'must-haves' list. For...
Aug 18, 2025
C
cyclops222
reacted to
Stinnett21's post
in the thread
Prop change on my bowrider
with
Like
A 21 4 blade will behave like a 23 3 blade, probably too much. I'd try a 21 3 blade. But first, check your tach. I would not expect a...
Aug 18, 2025
IslandExplorer
reacted to
redneck joe's post
in the thread
with
Like
Sheet and angle aluminum with a thousand or so rivets and you can customize to your heart's content. Just find a boat windshield the...
Aug 18, 2025
IslandExplorer
reacted to
AussieB's post
in the thread
with
Like
I did some quick research and it was mainly positive, but like anything I'm sure there are also negative. Not even sure how well an...
Aug 18, 2025
IslandExplorer
reacted to
AussieB's post
in the thread
with
Like
Like I stated earlier, I'm just in the early stages of research so I'm not rushing out to buy a boat. All the ducks need to be in a row...
Aug 18, 2025
