Scott06
replied to the thread
Milky oil from oil cooler failure
As mentioned just keep changing oil and filter get cheapest oil and you don't have to completely fill the oil pan just run it for a bit...
Aug 19, 2025
P
Pmt133
2005 4.3 liter Mercruiser ignition trouble
You could check 12v into the ignition switch since you're losing it there. If the supply side of the switch is fine your problem is the...
Aug 19, 2025
R
robertw007
69' Whaler Nauset
Well that's a relief. I ran a drill bit in the transom in a few places. Darkest was at the drain tubes, they were awful when I pulled...
Aug 19, 2025
C
carlos515
Changing colour of gelcoat question
I lifted the boat off the rollers, the rollers were indenting the hull. I think removing the wobblers and turn the trailer into a bunk...
Aug 19, 2025
tg3690
1990 Force rub rail question
You might try posting this in the Restoration forum......probably get more responses over there......rub rails and such are pretty generic.
Aug 19, 2025
redneck joe
1986 Ski Nautique 2001 resto project
Yeah baby, that's sexy....
Aug 19, 2025
redneck joe
reacted to
TRH299's post
in the thread
with
Like
Aug 19, 2025
redneck joe
File uploads no good again?
Don't forget to change the banner
Aug 19, 2025
J
Jk100585
Idle Issues - 1980 Johnson 115 - J115TLCSA
Does anyone have insight as to what could’ve happened to spark after I installed the tach?
Aug 19, 2025
southkogs
reacted to
tphoyt's post
in the thread
Nice fish
with
Like
This beautiful tuna was caught of Chatham Ma on Saturday. 110”
Aug 19, 2025
J
Jeff J
Epic launch
I used to launch a boat with a 69 Bronco I owned at the time. I kept the rear brakes serviced and adjusted because I wanted that parking...
Aug 19, 2025
C
carlos515
Well I just finished tenting my boat. The exhaust air supply is hooked up. Now to start removing stringers and grind.
Aug 19, 2025
L
Lpgc
reacted to
badrano's post
in the thread
High Fuel Pressure
with
Like
Interesting analysis. I know my wallet felt that 32% richer mixture. :)
Aug 19, 2025
K
kepruno
I did pull the connector. There is no corrosion of any kind. It looks brand new. For some context this boat has spent most of its life...
Aug 19, 2025
reacted to
tphoyt's post
in the thread
Nice fish
with
Like
Aug 19, 2025
