redneck joe
reacted to
Fj40fiji's post
in the thread
I didn't want to restore this 1997 Islander this summer
with
Like
Laminated, sprayed with 3M cavity wax, and new wood installed with new hardware and through TH Marine through hull fittings (I did reuse...
Aug 19, 2025
B
bring
reacted to
saabsaviorlee's post
in the thread
bow mount trolling motor on 12.5' SIB
with
Like
It can be done!!! After struggling to operate a transom troller and getting it to fit next to my outboard and launching wheels and...
Aug 19, 2025
F
Fj40fiji
replied to the thread
I just made Second Class! That was my rank when I got out of the Navy.
Aug 19, 2025
F
Fj40fiji
If I had it to do again, I think I would’ve tried to make a good buck and form a new transom. I am pretty confident in this repair, but...
Aug 19, 2025
M
MikeSchinlaub
69' Whaler Nauset
I wouldn't drill holes through the transom. It'll just be added body and paint work when you eventually replace it. I know it sucks...
Aug 19, 2025
arks
boat snap on covers
Find a local company and have it made. Shouldn’t be terribly expensive. I just had this replacement bimini top made from Sunbrella and...
Aug 19, 2025
guy48065
Prop change on my bowrider
Clear up some shopping confusion for me. I've noticed once you get up in the 135+ hp range that "outboard" and "sterndrive" props look...
Aug 19, 2025
C
cyclops222
cowl air inlet on mercury 9.9.
My old Evinrudes look like they have no breathing opening. They have gaps around the bottom of the cowling to keep water & spray out of...
Aug 19, 2025
R
robertw007
69' Whaler Nauset
Hey Scott, I wasn't able to find that table. If 750lb is the case. I'm set. If not I've got to consider alternative avenues. I'm...
Aug 19, 2025
C
Tell tale not peeing
A lot of those V6 Mercs have the telltale downstream of the thermostats. That is, until the engine is warm, there will not be a...
Aug 19, 2025
J
jlh3rd
Is A I a totally unreliable function ?
darn...I forgot where I dug my bunker !😬
Aug 19, 2025
C
Advice needed - low water pressure and cold engine temps
If the cooling system is like other Mercs, the idle temp is controlled by the thermostats. At 2000RPM or so, water pressure pushes the...
Aug 19, 2025
F
Fj40fiji
Putting the rub rail channel back on I decided I should be able to buck my own rivets. The original holes weren’t laid out consistently...
Aug 19, 2025
2005 4.3 liter Mercruiser ignition trouble
The key switch purple wire has 12V with key ON and 4V when cranking. The red/purple wire comes from the 50 amp breaker on the motor, to...
Aug 19, 2025
C
82 50 hp tilt and trim
The trim switch will only operate if the trim limit switch is closed. The trailer switch should operate at all times. The trim limit...
Aug 19, 2025
