Texasmark
reacted to
alldodge's post
in the thread
LOWER END OIL CHANGE
with
Like
Don't have one that old. Checked Mercruiser Alpha and Bravo and they are 40 in-lb. The Verado OB is 100 in-lb This manual list 55...
Aug 20, 2025
Texasmark
replied to the thread
Tell tale not peeing
On some Mercs, the little hole in the front of the midsection or LU...forget which is the pickup for the speedometer. Easy to tell as...
Aug 20, 2025
Texasmark
2004 Mercury 115 2 stroke - oil injection block off plate
I have done that to two engines, 90 and 115 Mercs. All I did was to unscrew the oil pump and remove 1 of its hoses (so that I could...
Aug 20, 2025
nola mike
On throttle up the engine dies
As AD said, need to know what ignition you have. EST works different than the TB or points.
Aug 20, 2025
Texasmark
Best Outboard Motor Brands for Reliability and Long-Term Use
Bought a new Johnson 125 HP in 1972 and kept it for 7 years. Kids grew up, no more Sunday outings after church, so I sold the boat...
Aug 20, 2025
anc switch.
ANC = Anchor light
Aug 20, 2025
J
Jeff J
I guess if you’re a “prepper” worried about what may still run after the aliens drop a big EMP on us, it may affect the decision whether...
Aug 20, 2025
J
Jeff J
Saying a 2-Stroke is better than a 4-stroke like saying the Go Devil in my ‘47 Willys is a better engine than the 4.6L in my Ford F150...
Aug 20, 2025
L
Lpgc
1996 OMC Cobra (Ford 302 / VolvoSX collaboration) sometimes runs hot
Thanks Kenny, When I get the time I will do as you suggest. When I bought the boat the engine was in bad condition with cracked...
Aug 20, 2025
FLATHEAD
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
It's been a while. I've been waiting for the pictures to work again. Here's the Basscat getting the Hamby. Then I worked on a semi...
Aug 20, 2025
L
Lpgc
reacted to
kenny nunez's post
in the thread
with
Like
Remove the hose from the drive to the raw water pump. Try reverse flowing that hose into the drive with the drive up, look at the...
Aug 20, 2025
C
cyclops222
WE all realize that any company with a computer controlled Product..........Can control when it DIES. Anytime after the warranty...
Aug 20, 2025
E
EvanB88
reacted to
Nordin's post
in the thread
71/72 105hp Propeller Clearance Issue
with
Like
Did the "new" LU come without the exhaust snout and you put the one from you cracked LU on it? I know there were two different snouts...
Aug 20, 2025
E
EvanB88
They are both 2-piece lowers. I did use the exhaust snout from the cracked unit on the replacement. Looking at images the earlier part...
Aug 20, 2025
C
cyclops222
reacted to
Scott Danforth's post
in the thread
with
Like
long term reliability..... old two strokes, hands down. if you maintain them, they last 75+ years as for most un-reliable. EFI...
Aug 20, 2025
