F
fiberglass93
replied to the thread
soft layer glued to sides on inside of fiberglass boat?
Could be glue yeah, but seems a bit thick I don't see any cracks but I want to coat everything with a layer of epoxy resin to fill any...
Aug 20, 2025
redneck joe
Nobody fishing?
I lived on a private lake as a kid, same plus the bass were over populated so they were all stunted. If the baby bluegill made it a...
Aug 20, 2025
redneck joe
reacted to
Fj40fiji's post
in the thread
I didn't want to restore this 1997 Islander this summer
with
Like
*Whipple- F’n autocorrect.
Aug 20, 2025
redneck joe
reacted to
Scott Danforth's post
in the thread
Boats from work.
with
Like
its a submarine.
Aug 20, 2025
N
Nordin
LOWER END OIL CHANGE
I have done it in the same way as Chris1956 in more than 30 years. Never have had an issue.
Aug 20, 2025
N
Nordin
reacted to
Chris1956's post
in the thread
with
Like
Jeff, hence the use of the hand impact driver. You first make the screws as tight as possible with a screwdriver, then use the hand...
Aug 20, 2025
bigblocksarefun
are there boat "salvage yards" anywhere in the U.S.?
https://massmarineparts.com/ https://www.laniermarine.com/ https://www.obparts.com/ https://www.americanoutboard.com/...
Aug 20, 2025
FLATHEAD
Maybe EVs don't make the best Getaway Cars ...
Mighty expensive mish mash of Dennys paraphernalia for those two knuckleheads
Aug 20, 2025
Rear main seal 5.7
PTFE is Polytetrafluoroethylene which is a fluoro elastomer
Aug 20, 2025
that looks like glue that set prior to carpet going in. if you have cracks, epoxy resin by itself wont do anything. you need to add...
Aug 20, 2025
sx-a driveshaft bellows full of oil but no leak detected under pressure and vacuum test
Then the only thing I can suggest, fill it, run it, check it often. look again when you pull the drive for winter maintenance.
Aug 20, 2025
M
Mc Tool
reacted to
redneck joe's post
in the thread
Best Outboard Motor Brands for Reliability and Long-Term Use
with
Like
What is the purpose of this post? You own a boating company selling parts and such, one would think that you would know the answer to...
Aug 20, 2025
nola mike
What is this indicator? (2000 Bayliner)
I'm able to download the PDF and can see it without blurriness. shoot me a pm if you want it
Aug 20, 2025
R
roonie
posted the thread
1986 90 hp johnson trunion
in
Johnson & Evinrude Outboards
My manual tells how to adjust the upper trunion but for the life of me I can't find anything on how to adjust or the purpose of the...
Aug 20, 2025
F
fiberglass93
posted the thread
in
Boat Restoration, Building, and Hull Repair
Hi everyone, I'm in the process of restoring a boat and ran into something I'm not sure about. After ripping out the old carpet, I...
Aug 20, 2025
