R
runninfarmer
replied to the thread
Lower unit oil leak through weep hole after impeller replacement
Splines are dry, but shaft was wet to about right at base of splines and on top of pump housing all wet with oil. Also from what I can...
Aug 20, 2025
SO your saying the splines are wet with lube at top of shaft, down to on top the pump housing?
Aug 20, 2025
R
runninfarmer
tried it again, this time with aviation gasket sealer on the quad ring. Happened again. One thing to note, I still had the reservoir cap...
Aug 20, 2025
redneck joe
Random
This is about the age this became my job https://www.facebook.com/share/r/19iB98CaqW/
Aug 20, 2025
Scott06
Volvo Penta SX-M Mysterious Rattle. Not U-Joints. Not Gimbal.
Only thing I can think is gimbal bearing is not fully seated or the new drive has a bad bearing in it
Aug 20, 2025
Scott06
Alignment adjustment, witness marks
I’m pretty it’s It’s inverse it witness marks are heavy on bottom then lower the front …as you’ve seen raising isn’t helping go back to...
Aug 20, 2025
C
cyclops222
reacted to
Mc Tool's post
in the thread
Flux Marine Outboard Engines . . .
with
Like
way back in the good old days when all there was was healthy natural foods .... life expectancy wasn't actually that good .:):)
Aug 20, 2025
S
svonadym
Schematic Diagram for Vintage Faria Tachometer
Thank you all for your responses. I contacted Faria, but as suspected they tell me they don't have that information (old unit). They...
Aug 20, 2025
aspeck
reacted to
FLATHEAD's post
in the thread
Maybe EVs don't make the best Getaway Cars ...
with
Like
Mighty expensive mish mash of Dennys paraphernalia for those two knuckleheads
Aug 20, 2025
2 stroke longevity?
Pro-Mac 610? If so, closer to 40 years old
Aug 20, 2025
N
Neil1982
1975 Johnson 70hp
Probably about 350 lbs in people and gear, plus 6 gallons of gas. to get 35mph i have to put the trim rod about 4 holes up.
Aug 20, 2025
What year is this Johnson?
Closed please read our rules
Aug 20, 2025
bajaman123
boat snap on covers
BOATCOVERSDIRECT.com
Aug 20, 2025
C
crazedalizamg
I hope you are still on this forum. Would you like to sell it to me?
Aug 20, 2025
G
GUS 79
reacted to
Candy Gramformongo's post
in the thread
Throttle Only Button
with
Like
It was a piece of cake. You may see a reference to some extensions needed, but I did not need them. The cables just drop into position...
Aug 20, 2025
