bigblocksarefun
reacted to
TRH299's post
in the thread
1986 Ski Nautique 2001 resto project
with
Like
Yanked transmission out last night... Split case and found the two reverse clutch plates were broke and the 12 return springs were...
Aug 21, 2025
garbageguy
replied to the thread
Helpful thread and pics, thank you! That boat looks great, definitely better cosmetically than our 1991 Mastercraft. We're OK...
Aug 21, 2025
E
evantful
Alignment adjustment, witness marks
Well thats what odd, I can install it and remove the bar with two fingers. That's how I thought about it too, pressure on the bottom...
Aug 21, 2025
Grub54891
reacted to
Scott Danforth's post
in the thread
Steering at low speeds - Volvo Penta
with
Like
since these pumps generally can withstand a nuclear blast and continue to run without issue, the most I would do is get a rebuild kit...
Aug 21, 2025
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
This is about the age this became my job https://www.facebook.com/share/r/19iB98CaqW/
Aug 21, 2025
A
airshot
LOWER END OIL CHANGE
Get a " low head" bolt....looks just like a factory plug but has a hex drive in the center. Often the outside dia of the head is to...
Aug 21, 2025
Grub54891
reacted to
alldodge's post
in the thread
Hot water heater
with
Like
Don't see any issue with the setup at the water heater. I'll go back to in post 2, think the hot/cold lines are swapped/mixed up All...
Aug 21, 2025
A
airshot
reacted to
cyclops222's post
in the thread
with
Like
How do you know what to set the impact driver to ? What peak Foot Pounds can be checked ? I changed mine to S S Allen Head Screws...
Aug 21, 2025
A
airshot
reacted to
alldodge's post
in the thread
with
Like
Don't have one that old. Checked Mercruiser Alpha and Bravo and they are 40 in-lb. The Verado OB is 100 in-lb This manual list 55...
Aug 21, 2025
jerryjerry05
1986 85hp force 856X6L no spark
You said: As far as the twins issue it was my fault I should have changed all the wiring in the electrical system because vibration will...
Aug 21, 2025
A
airshot
1986 90 hp johnson trunion
It used to be that way...m
Aug 21, 2025
Hot water heater
Aug 21, 2025
T
TRH299
Aug 21, 2025
jerryjerry05
reacted to
EvanB88's post
in the thread
71/72 105hp Propeller Clearance Issue
with
Like
They are both 2-piece lowers. I did use the exhaust snout from the cracked unit on the replacement. Looking at images the earlier part...
Aug 21, 2025
jerryjerry05
Can't open cover on a US Marine Force 50
The 80's 50hp. One of the better runners from Force/Chrysler. This motor runs on one cylinder almost as good as 2. Use good oil and...
Aug 21, 2025
