MNhunter1
replied to the thread
Is it only a matter of time for leaks?
V5's are hard to come by as it is. You may be waiting for a while to find a good deal on a 22ft OB. I'd love a big 22ft'r, but my 18ft...
Aug 21, 2025
K
kd4pbs
reacted to
TRH299's post
in the thread
1986 Ski Nautique 2001 resto project
with
Like
Aug 21, 2025
D
DeepCMark58A
Best Outboard Motor Brands for Reliability and Long-Term Use
If and I do have a vintage outboard from the 50's it is a mercury, after that I was an evinrude guy. I have owned two Honda outboards...
Aug 21, 2025
K
kd4pbs
Gas guage
Unplug the sending unit when you turn off the boat to ease your mind as to whether or not it is just the way the gauge works.
Aug 21, 2025
K
kd4pbs
LOWER END OIL CHANGE
I just use my German torque wrench set to "Gootentight".
Aug 21, 2025
K
kd4pbs
reacted to
alldodge's post
in the thread
with
Like
I'll never use a impact to install
Aug 21, 2025
D
DeepCMark58A
Scary
Summer is stale here in Minnesota the State fair has started it's over. School will be starting up less traffic on the water.
Aug 21, 2025
K
kd4pbs
Flux Marine Outboard Engines . . .
Lots of ways to manipulate data...
Aug 21, 2025
B
badrano
posted the thread
Cool Fuel 3 Module Water Channels
in
Non-Repair I/O and Inboards
How do you determine when it's time to replace the CF3 module? Looking in through the water inlet/outlet holes, I see corrosion in...
Aug 21, 2025
R
roonie
1986 90 hp johnson trunion
Im simply going through a link and sync
Aug 21, 2025
C
crazy charlie
Lower unit oil leak through weep hole after impeller replacement
Quad O ring should be glued into place after carefully thoroughly cleaning where it is seated.This however does not sound like your...
Aug 21, 2025
Scott06
2 stroke longevity?
No pretty simple and easy to work on. I wouldnt worry too much if you have one that was taken decent care of
Aug 21, 2025
C
To each his own. I for one, do not want the gearcase plugs leaking or unscrewing, while I am cruising along.
Aug 21, 2025
K
kd4pbs
Schematic Diagram for Vintage Faria Tachometer
Are you sure that's a resistor? Alone and in series with the supply would be an odd place for a resistor. I'd love to see a picture of...
Aug 21, 2025
C
Gas guage
A lot of fuel gauges stop moving when power is removed. When they are powered they move to the correct fuel position. If the fuel tank...
Aug 21, 2025
