GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
replied to the thread
2005 4.3 liter Mercruiser ignition trouble
Including when the key is turned to start? If correct Post a pic of the back of the key switch with wires on it
Thursday at 5:49 PM
reacted to
Pmt133's post
in the thread
A couple more I/O questions...
with
Like
About 150 rpm above redline... 4950 or so.
Thursday at 5:46 PM
eggs712
reacted to
dingbat's post
in the thread
Bait and Livewell
with
Like
I too was taught to keep fish alive until ready to be cleaned. Wasn't until I mated on a charter boat as a teen that I learned keeping...
Thursday at 5:33 PM
9
99yam40
2001 200hp HPDI wont run, rebuilt pump, changed all filters, I'm stuck
did you clean the fuel tank? seems like it ran well until it was put in the water and was moving back and forth. maybe there is some...
Thursday at 5:24 PM
C
cyclops222
posted the thread
Caffeine good for sleepy old guy ?
in
Dockside Chat
How many old guys use a cup of Caffeine to become active enough for many hours ? I am ready to do it.
Thursday at 5:23 PM
nola mike
so test the resistance across the terminals is the ignition switch and see if you're getting continuity between b and i/s when in run/start
Thursday at 5:18 PM
H
Hand Crafted Angling
1986 Starcraft Mariner 160
She lives.
Thursday at 5:15 PM
soft layer glued to sides on inside of fiberglass boat?
Acetone does little for the carpet glue I used a wire knot cup brush in the angle grinder to remove glue and a bit of fiberglass
Thursday at 5:15 PM
K
kepruno
Yeah. Every wire except the purple has or gets 12 volts when the key is turned to start. To further clarify, every single wire is...
Thursday at 5:12 PM
C
cyclops222
reacted to
airshot's post
in the thread
LOWER END OIL CHANGE
with
Like
If properly tightened, why would they come loose ? Am I missing something ?
Thursday at 5:09 PM
nola mike
sorry, I misread it. so you do have 12v at the red/pur when cranking
Thursday at 5:08 PM
K
kepruno
To clarify. The supply wire never loses power. The tab where the purple wire is supposed to be connected is what loses power when the...
Thursday at 5:07 PM
K
kepruno
Please read the post again. That’s not where the power loss is.
Thursday at 5:04 PM
nola mike
that red/purple is always live. it isn't a problem with the switch if you're losing power at that wire when cranking.
Thursday at 5:02 PM
C
cyclops222
reacted to
tphoyt's post
in the thread
2 stroke longevity?
with
Like
I read a story once about a Chinese tool manufacturer that refused to keep making a product for a company because they kept asking them...
Thursday at 5:02 PM
